03-10-2025 12:51 PM in
Wearables- Mark as New
03-10-2025 01:09 PM in
WearablesHi Sameep,
We understand how frustrating it can be to encounter static sounds while using your earbuds. Please try the below steps to solve the issue:
Reset the Buds: Use the Galaxy Wearable app to reset your earbuds to their default settings.
Please ensure your Galaxy Buds 3 Pro are running the latest firmware version through the Galaxy Wearable app.
Check Ambient Sound/ANC Settings: Adjust or disable Active Noise Cancellation (ANC) or Ambient Sound mode to see if it reduces the static noise.
Clean the Buds: Gently clean the earbuds and charging case to remove any dirt or debris that might interfere with audio quality.
Test with Another Device: Pair the buds with a different device to rule out any issues with your phone.
If none of these steps help, we recommend visiting Samsung authorized service center to get it examined by the service technician to get it fixed.
https://www.samsung.com/ca/support/service-center/
Thank you.
03-11-2025 01:30 PM in
03-11-2025 01:26 PM in
Wearables
