Sleep mode turning auto on - problem, Galaxy Watch 6
(Topic created on: 10-26-2023 01:18 PM)
dawidmos
Beginner Level 4
Wearables
Hi,
I had very annoying problem with my watch. It's automatically turning on sleep mode on watch and syncing it to phone s23. Turning off sync setting giving sleep mode on watch only - this is not solution. It's turning on 22,00 everyday. If I will turn it off, after some time option will back as turned and synced on. It's very annoying, there is some resolution for it? Without disable sync and whole reset. Something normal?
Dawid.
2 Comments
xxaidennnyu
Wearables
my watch 6 has a same problem
gman72
Wearables
Same thing happening with watch 4 and s21fe
