DomD
12-11-2022 05:05 PM in
Wearables
7 Comments
DomD
12-11-2022 06:14 PM in
Wearables
I assume it is with gps on ?
KOTS21
12-11-2022 08:07 PM in
Wearables
This is my usage without GPS
GG2
12-11-2022 08:15 PM in
Wearables
Do you recommend the 5 pro? Thinking about buying a smart watch, not decided yet.
KOTS21
12-11-2022 08:31 PM (Last edited 12-11-2022 08:31 PM ) in
Wearables
I like it and it depends what you want to use it for. If you're using just as a watch I wouldn't get one but if you're using it to track workouts,steps, heart rate and other physical activity I would say yes. I need one because the work I do I usually have my phone in my pocket and miss text/calls from either noise or can't feel the vibration. It's a solid made watch but I don't see a huge difference between the GW4 and GW5 pro except for the battery. I have them both.
GG2
12-11-2022 08:39 PM in
Wearables
Thanks for your input, appreciate it.
KOTS21
12-11-2022 08:41 PM in
Wearables
My pleasure
