Watch 5 pro mobile plan
(Topic created on: 11-21-2023 04:50 PM)
SgtStubby
Wearables
I bought my 5 pro used and in the app it shows a Telus mobile plan I can turn on and off. Is it still linked to the previous owner?
16 Comments
Ray1
Wearables
I think it might be because you shouldn't see this normally
SgtStubby
Wearables
Where it says SERVICE STATE it says in service
Ray1
Wearables
Then it likely still is but unless you want to pay on their account it will likely disappear shortly🤣
Ray1
Wearables
I think if you were to reset the device this would likely disappear but not certain as I have never ran into this
SgtStubby
Wearables
I set the watch up under my account when I got it. So it must see the esim on the network
Ray1
Wearables
But did you reset the device
This would remove anything from before you purchased it which I think would be best incase there is something we are not aware of carried over from previous owner as spyware etc etc.
SgtStubby
Wearables
Ya I rgink it automatically wipes it when it's connected to a new phone.
Ray1
Wearables
If it did you wouldn't be seeing any thing from previous owner
I would just reset the watch and set it up as your own and then you are good
SgtStubby
Wearables
So if you buy a used phone with a sim card on a valid plan it won't show up after you initialize the phone with your info?
