samsung A12 problem
(Topic created on: 11-14-2023 11:06 PM)
killues
Gaming Hub
im only have this problem? my wifi connection speed is up to 500mbps but my connection speed si only up to 72mbps. i can't enjoy my gaming experience on this phone.
5 Comments
TeamGalaxyDD
Gaming Hub
Hey killues,
Your Galaxy A12 unfortunately does not support 5GHz WiFi, which is why you may be experiencing slower speeds on your A12 compared to other devices.
However, 72Mbps should be more than enough speed for gaming. Most games (like MLBB, for example) use up only 5MB - 10MB per 15 minutes, less if games are faster. It shouldn't be too much of a strain for your connection.
killues
Gaming Hub
should be more enough? really, wow. what do you think im doing here? to report right? because its not like before. i remember when i used only android 10, this playable but when i upgrade to android 12 or 13 something, i experience delay and not playable. the same problem i found on google this is her problem
killues
Gaming Hub
btw i know my device not supported 5ghz wifi but dude im want just enjoy but unfortunately i can't. pls help me with this problem. only moba games affected this laggy and delay like mlbb and wild rift
jayzawu
Gaming Hub
Just upgrade ur phone if kaya mo naman magbayad ng 500mbps monthly why stick to a cheap a12?
killues
Gaming Hub
di naman ako nagbabayad ng wifi, tyaka di lang naman ako may cp samen. gusto ko lang malaman kung ako lang nakaranas neto. kase legit di ganto dati to nung android 10 pa, e excited ako sa new feature ng android 13 kaya inupgrade ko from 10 to 13 tas ganyan na
