Battery Problem on A51
(Topic created on: 02-08-2021 09:48 PM)
AyxiXD
I just bought this phone 8 days agoo,after buy it..it is 0%battery,after that i charge this phone while downloading the updates,n then update the phone while charging,then i use it as well but the batterylooks weird..then i do do as what u guys sag but its just the same??it is just because the phone problem or the updates problem??need help..
16 REPLIES 16
The first few weeks of using your battery, the battery is actually learning how are you using your phone. After 3 to 4 weeks your battery will be stable. Mark my answer as solution if it helps😊
AyxiXD
ok babe,thankss...
Remember mark my ans as solution😄 thankss
AyxiXD
but when i dont use it,it will become 79% to 77%,but when i use it..it feels like 1% for every 3 minutes
Yes, my Note 10 Lite also drain ultra fast when i just got it, but few weeks later it became good
AyxiXD
how did u know??
The battery used to last only 3 hours in the first few weeks, now it lasts a day
AyxiXD
do you mean that its has to practice to learn first??🤣😅
Yes it is learning how u use your phone
