스하위켛크분
04-09-2020 01:49 AM in
7 Comments
ZakariaID
04-09-2020 02:53 AM in
wipe cache partition brother. it's very useful
ZakariaID
do you know how to do it ?
SamNoteUser
04-09-2020 06:31 AM in
Wipe cache partition
Turn the phone off.
Press and hold the volume up and power buttons.
When the Android logo appears, release the volume up and power buttons.
You will see an Installing system update message for anywhere between 30 and 60 seconds.
In the system recovery menu options, press the volume down button to toggle the selection to wipe cache partition.
Press the power button to select wipe cache partition.
Press the volume down button to get to toggle the selection to yes.
Press the power button to select yes.
Press the power button to restart the device once the Reboot system now option appears.
Turn the phone off.
스하위켛크분
04-10-2020 01:15 AM in
after i upgraded to android 10, i did factory reset my phone. hence everything was clean, but phone is heating and battery drain fast
TommyOliver
04-09-2020 03:05 AM in
there could be a problem with google play services... saw a video on youtube bout this issue...
Sy3ney
04-09-2020 07:55 AM in
Phone is indexing after major updates. Loading all the apps etc will drain battery after updates. Try use the phone for 3-7 days and see the changes whether still persist.
스하위켛크분
04-10-2020 01:17 AM in
last sunday was upgraded to android 10, today is 4th day, phone still heating and battery drain fast. will see after 7 days how it goes.
this phone not yet a year since i bought, hence i believe and sure not phone issue because android 9 have no such issue.
