Need help with charging warning notification.
(Topic created on: 12-10-2021 10:59 AM)
NaithKK
Galaxy Note
Anyone know how to re-enable the charging warning notification that pops up if a charging cable isn't plugged properly or is damaged and not charging optimally? I accidentally checked the "do not show this again" checkbox and now the popup is gone and doesn't look like there's any settings to re-enable it.
8 REPLIES 8
vyan1105
Galaxy Note
Hi dear, u can try go to setting > notification > see all > 3 dot option button : show system apps > search system ui > can select from there which notification u want to show. Screenshot_20211210-113004_Settings.jpgScreenshot_20211210-112952_Settings.jpg
NaithKK
Galaxy Note
Hi, I have gone to these settings and to the System UI process and there's nothing there to enable the popup notification like before. The reason I prefer the original one is because it immediately shows the warning as a popup instead of placing it as an entry in the dropdown list... Screenshot_20211210-141336_Settings_30622_1639116827.jpgScreenshot_20211210-141417_Settings_30624_1639116867.jpg
NaithKK
Galaxy Note
The show as popup thats turned off only shows it at the top part of the screen temporarily before disappearing. The original one shows a popup at the bottom half of the screen and doesn't disappear until you press the OK button
vyan1105
Galaxy Note
Last suggestion 😂 format ur phone Haha to factory reset
NaithKK
Galaxy Note
Yes its the last resort... although extreme for just a setting... wish Samsung had the option somewhere instead of having to do a factory reset.
vyan1105
Galaxy Note
😂 maybe we are not expert enuf to know where to turn it back
vyan1105
Galaxy Note
If accidently turn off, always can turn on 😌👍🏻
Darkprincess0
Galaxy Note
How do I do it for android 13?
