note 10 got problem for mobile data ?
(Topic created on: 11-22-2019 04:25 PM)
YebPilgrim
Galaxy Note
Been used for 2 months now. I join fb group for malaysian note 10 user. Read some said note 10 got slow connections for mobile data. I realize its true. Btw its malaysian model using exynos not snapdragon.
So is this true or just my feeling?
If true what is solution to this?
7 REPLIES 7
Reshsu
Galaxy Note
not only note 10..note 10+ dual sim problems..when use dual sim data connection slow..
marvinlen
Galaxy Note
Note 9 too.Weak signal for mobile data.
TerranceVens
Galaxy Note
No problem for me tho. I only heard N10+ got this problem but not N10. Maybe N10/10+ still new. Bunch of updates might rectify this outcome. We'll have to wait I guess.
mrschichi
Galaxy Note
so far, this is my 2nd month using the note 10, so far so good. l only have issue with the battery longevity. i mean 3500mah, i charge 2x daily if i actively used the phone
FaisalSabri84
Galaxy Note
thankfull i didn't face any problem with the data. when update any apps, the process very speed & smooth. maybe telco providers are doing some Maintenance at certain area. try to call your telco provider for further details.
Edster89
Galaxy Note
I use maxis okey specially my area strong signal. There are times drop that also if heavy cloud or rainstorm like astro. Note 10 plus here.
Sy3ney
Expert Level 3
Galaxy Note
Once your mobile data fully use it will be throttled to slow connections.
