Note 20 5g camera with flash issue
(Topic created on: 09-27-2020 02:54 AM)
Polarlights
Galaxy Note
I recently use my camera with flash and found out there's issue capturing with flash. It's over expose (it's like there's bright light in front of you) and couldn't focus to object. I found out it worked with near object capture only, but not worked always.
I am suspecting the problem caused by camera screen protector.
To make sure that, any other user had similar issue?
3 REPLIES 3
scinex
Galaxy Note
Do you have an example of affected pictures? Btw, you installed a screen protector on camera lenses?
Polarlights
Galaxy Note
Example of image is attached. Yea I do installed screen protector as it is exposed. (I'm new to this new design)
if there's no other similar issue I guess it probably my screen protector problem.
scinex
Galaxy Note
Possibly that's the reason. If you scared of scratches, maybe by using a thick phone cover helps.
All the best.
