Resolved! Solved
Rattling sound/Loose part sound
(Topic created on: 01-02-2020 03:08 PM)
zhenson
Galaxy Note
Hi all, note 10 plus users especially, does your unit produces some rattling sound or loose part sound when u shake your device?
My 1 month old device is like something broken or loose internally. The sound can be heard when the phone being shaken.
musz
Galaxy Note
its the camera focusing mechanism,if im not wrong..chill up man,nothing wrong..try open the camera app and shake..it will be mo louder
9 Comments
Ngai
Galaxy Note
camera aperture lens sound, nothing harm
Edster89
Galaxy Note
Did u drop ur phone before if not its the camera stabilizer.. No worries.
musz
Galaxy Note
zhenson
Galaxy Note
so it is perfectly fine n normal? does you guys' unit have such noise too?
Edster89
Galaxy Note
Yeap. I realise this when I jog cauze I hold my phone
Edster89
Galaxy Note
Besides the rattling sound. The phone function seems okey right.?
zhenson
Galaxy Note
perfectly fine
Sy3ney
Expert Level 3
Galaxy Note
no worry, it normal. The same sound appeared when i shake Shopee coins.
zhenson
Galaxy Note
hahaha.. thanks for your clarification
