Slow unifi wifi connection on samsung note and tablet
(Topic created on: 06-02-2021 08:15 PM)
Cooi11
Galaxy Note
Hi wondering if anyone experiencing the same problem.. recently install unifi wifi 100mbps and found that while other brand gadgets has stable connectivity to unifi wifi while both my note20 ultra hp and my son's samsung s6 lite tablet has unstable n low connectivity to unify. Any solution?
6 REPLIES 6
Galaxy Note
I'm not sure, I have the exact same unifi 100mbps
Cooi11
Galaxy Note
And you dun see any issue?
vyan1105
Galaxy Note
Is it only happen for samsung phone ? I think u cn try check is telco problem or simcard problem~ get helps there cn self check the wifi connection , u might give a try
Galaxy Note
Yes i rethink and I feel like my mobile data is downloading stuff faster than my wifi even though unifi has 100mbps speed
StephCY
Galaxy Note
I don't think it's your phone. Possibly just Unifi since it's been overeorjed as everyone is online working or doing online learning.
Cooi11
Galaxy Note
Thanks for the responses.. my connection improved after i got the tp link deco for the house.
