noorsyafiqm
10-10-2025 08:24 PM in
After updating my S24 FE to One UI 8 (Android 16), I realised that most apps (specifically the banking ones), will not close/log out fully after clearing the Recents panel. Does anyone also facing this issue after the update? I do not wish to factory reset this device as I have work apps configured.
3 REPLIES 3
bersjx
10-11-2025 04:27 PM in
Try clearing your cache
mandrix
Beginner Level 4
10-21-2025 09:53 AM in
Galaxy SI'm facing the same issue. Did you find any fix?
noorsyafiqm
11-04-2025 08:53 AM in
I think either the new update patch ot the updates for my banking apps solves the issue.
