Exynos S21 FE Power button and Screen Freezing
(Topic created on: 03-04-2022 08:57 PM)
Up3kkha88
I've been using the S21 FE for about a month+ now, and there's indeed a few bugs (mainly the screen refresh rate issues that makes the screen feel less smooth & stuttery).
However, recently I've encountered an issue where I wasn't able to close my phone (pressing power button). I pressed the power button and it either doesn't respond or it turned on the flashlight. I've set a single click to close the phone and double-click to turn the flashlight on btw.
Then, at the same time, the screen wasn't responding well to my touches, clicking apps will not launch etc. Basically, the screen was freezing.
I had to restart the phone in the end, which while doing so, lags for several seconds only it registered my intention.
After restarting, all is well again, though of course the occasional refresh rate bug still strikes.
I really hope Samsung could fix the performance and Screen issues of Exynos S21 FE.
1 REPLY 1
Prashantgadhwal
Beginner Level 4
Brother I am facing same issues samsung must replace this smartphone videos and games lag when I use screen refresh rate continuously 120 hz
