Galaxy S10e battery replacement
(Topic created on: 07-30-2022 03:27 PM)
Jimonji
Anybody have experience replacing the S10e battery? How much does it cost? Tq guys
2 Comments
The estimated cost to replace the Galaxy S10e battery is RM160 excluding the labour cost.
Labour cost varies from RM60-RM85.
Appreciate if you could click the three dots on top right (kanan bahagian atas) of this comment and select ACCEPT SOLUTION if you're satisfied with my answer. Cheer!
GunasamssYT
You can check it online. It's estimated to be between RM130 - RM200. Also for the service cost (Like to open the phone and replace the battery and close the back glass back) might cost RM50 - RM90. So yeah 👍
