How's S22 Ultra battery for you guys?
(Topic created on: 03-08-2022 08:28 PM)
ethanB
How's you guys battery? Average screen on time able reached 5-6hrs only. Any idea to get best exceed 7-8hrs 😅 ?
23 Comments
scinex
Mine in general around 7 - 8 hours.
ethanB
How's is it possible, mind share any tips?
scinex
No idea😅. But I don't have any games installed. Also no 3rd party apps which have ads. If there is, I will uninstall it.Screenshot_20220308-204219_Device care_9573_1646743339.jpg
ethanB
Great battery and usage you can achieved there. I have no idea how.
My current setting: Always Dark mode, 120hz and FHD screen resolution. No game for the moment. messaging, social media and YouTube majority.
Third party apps ads so far no that I have encounter....
scinex
Almost similar setting here. Always dark mode, and for apps with dark mode option, a must to set it ON and 120Hz adaptive. Only difference here is my resolution is set to the highest, WQHD 😅.
scinex
One thing I see is different from you. I'm using only one line but you use both lines. Maybe this drains more batt?
ethanB
Emm maybe is another possible factor
if you don't mind, try select all your apps and put in in deep sleep mode, except for some apps that you concern about their frequent notification
