S22 Ultra Android Auto (via cable) Problem Solved
(Topic created on: 04-14-2022 08:00 PM)
Members_ynPeBnj
  • To all users of S22 who have facing unable to connect Android Auto to their vehicle, I have solved the problem and it work perfect now. To connect to AA we need to use the original cable comes with the S22, cannot use third party or even other Samsung cable. It has to be the one come with S22. For vehicle using USB type A, you need to buy a converter to connect the type C to type A (USB 2.0).
I have the problem which I cant connect to AA thru other type A to type C cable which work well on my Samsung A22 but it doesn't work for S22 Ultra. I just bought the Baseus converter and work perfectly via original S22 cable. Hope this info can help you guys. Samsung technical please take note on this matter.
7 REPLIES 7
Brmonte88
I tested this and doesn't work on my pioneer AVH-5280TV. This screen still with a black image
adrianlms
I have a S21 FE and this did not work for me on my Honda CRV 2017...
Motleyshue
Did not work with my Mercedes Vito. Tried USB2 and 3 now.
EthanC3
My S22 suddenly didn't work after weekend Android update.
Members_cG5nKEO
is there really cable issue or just simply the updates issue ?
DamienHr
Hello ! It has already been mentioned here that Honda does not have good contact with Android. I want to confirm this with the example of my Honda Civic 2021. I have already begun to regret a little that I chose this particular brand, since I have to be very careful with tires too. Yes, yes.. I'm planning summer kit orders now with online tires canada - https://tireplanet.ca/ It seemed to me that the transmission slightly increases the torque beyond what is necessary, so tire wear becomes greater. Plus this small defect with electronics. In general, keep this in mind.
It worked for my Kia Niro EV.  Never a problem with older phones.  Used cable that came with phone and it worked like it is supposed to.
