S22Ultra UI7 android 15 lock screen problems
(Topic created on: 05-12-2025 01:57 PM)
Aldenloo
Is anyone experienced lock screen keeps lock and unlock by itself after update to new UI7. After restart problem persistent.
5 REPLIES 5
Aldenloo
Now my fold 5 experienced the same issue and goes into safe mode. What happened??
Samsung_MY
HI @Aldenloo,
You'll need to contact support to see what's happening (they will take you through basic troubleshooting), and if unsuccessful, will need to be looked at by a technician.
You should also send an error report via Members (long hold app > error reports) for support team to log and look into the issue.
Hope this helps!
Aldenloo
Already sent. I walked into the cust care branch at gravitas Penang. They are unable to help but need to fact reset. So, I have factory reset my S22 Ultra n lost some of my important data Fold5 is the next one. 😑
Amir_13
You need to backup external just with samsung smart switch
Aldenloo
It's too late. Already fact reset. Thanks for you advice ye. 🙏
