NateJjs
02-09-2024 09:26 PM (Last edited 02-09-2024 09:26 PM ) in
						Anyone facing this issue?
		1 REPLY 1
			NateJjs
02-10-2024 12:08 PM in
						Found a way and it did help. Hope this will help u all too.
1. Proceed with a soft reset on your device. Please turn off the device by pressing and holding the power button and volume down together for 7 seconds. By doing a soft reset, you’ll be effectively discontinuing running applications and services, potentially fixing the issue.
