S25 battery percentage display
(Topic created on: 03-04-2025 11:17 PM)
Members_ACeLL77
S25 battery percentage is now displayed inside the battery icon which is ridiculously small and difficult to see with the changing battery levels. UI/UX is getting from bad to worse! Am I the only one feeling so? Can Samsung move back the percentage display out of the icon like all previous versions?
3 Comments
Mogay
i like it because finally battery indicator has a function, i still have one ui 6.1 and i hide my battery indicator
anyway you can't change back to older version however you can always hide it, install good lock + quickstar from galaxy store , inside quickstar there's option to hide battery indicator. Then you can use battery widget to show you phone/watch/fit/ring battery percentage
ChanCW
Beginner Level 3
I fully agree. It's difficult to read the battery percentage now. Information like battery percentage should be readable at a glance. It's important for some people.
AshAmeer
I'm with u guys , its so difficult to see the battery's load. Why change something which works . Pls renew bk the renewed b%tt icon.
