Samsung Galaxy S24 Static Sound
(Topic created on: 03-03-2024 12:50 PM)
Rashekka
Hey guys, I'm hearing a static noise from S24 when on call, the sound comes during call only, especially when I place the phone on my ears and listen, so I think the above the sound comes from speaker, when I test in loud speaker, I don't hear the static sound from the main speaker. Upon checking with Samsung, they saying it is normal. Do advise me on this. Been 2 weeks since I bought this device.
4 Comments
wan10
hope you found the cause and the solution soon. Didnt encounter any issue yet on my S24, just a bit confusing setting up and making over all the new features in this phone, adding up goodlock apps 😅
Encode_GR
Beginner Level 3
I have exactly the same issue, as many other people do, in Reddit.
Coil whine, buzzing and distortion, from top speaker, especially noticeable during calls. (It's always there, but outside calls is barely noticeable)
This is definitely NOT normal. Whoever from Samsung told you that it is, is a clown, and should not be working there. This is infuriating.
This is either a defect with the top speaker or motherboard (due to the coil whine noise, which is related to the chip capacitors), or it could be just a driver/software related bug that may be fixed.
I hope *moderators* here pick it up, so that Samsung finally acknowledges it and does something about it.
skokec71
Hi. I have the same isue here with my new S24. During calls I hear digital noise - but on the other side, the caller hear much stronger noise, so he can't understand me. Noise on other side - I think - is not present all the time. Even if I move and change location is the same isue. Not good exoerience for such money I have paid...
skokec71
My problem SOVED
I must say sorry to Samsung. The S24 is like it should be. The problem with digital voice was not from the mobile itself - but the FLIP COVER. I bought flip cover from China and almost all of them have magnets inside. This was the reason. And even mobile signal is now much much better - without using flip cover.
I've opened cover and from both sides there is quite large (and strong) magnet plate. This impact to the mobile.  So if you use flip covers with magnets in - check that first.
