03-07-2022 09:12 PM in
Galaxy S- Mark as New
03-07-2022 09:30 PM in
Galaxy S1) restart your phone
2)reconnect android auto with your car. Like unpair and pair it back
3)Check wether the android auto is updated or not in the settings.
Next, check for software update and if have a update than update it.
04-21-2022 11:26 PM in
Galaxy SI did all of those things, still won't see my apps, i.e. google maps and music apps etc. I can make phone calls and see who's calling, but not any apps. Says can't find any.
03-07-2022 09:54 PM in
03-08-2022 01:29 AM in
Galaxy SI bought S22 Ultra last week and surprisingly found its Android Auto doesn't work, just exactly same issue as yours. Meanwhile the Carplay worked perfectly on an iPhone 7🤣
03-08-2022 01:46 PM in
03-08-2022 02:00 PM in
03-09-2022 12:13 PM in
Galaxy SBack to your issue, for starters, highly recommend for you to use suitable cable, then from your phone, to create a proper handshake connection between devices, please enable usb debugging features from developer option (one-off to enable, you may disable this option after successful connection). Before that, you might need to enable location services, bluetooth, wifi and enable any other related option i.e nearby device scan, wifi scan, bluetooth scan. later, follow any screen prompt from your phone to successfully complete the connection.
mine got none of any problem connecting my z flip 3 wirelessly to android auto from my kenwood player.
If there's any problem persist, probably your android auto phone apps or samsung phone security level or car head unit player firmware need to be updated.
03-09-2022 12:39 PM in
03-09-2022 12:45 PM in
