Why does samsung s 22 ultra battery drain so fast
(Topic created on: 10-31-2024 01:28 AM)
MJOFFICIAL
I bought an S 22 ultra an I can hardly getb6 hrs of screen time..can samsung please make an update to consume less power like the s23 an 24 ultra I don't wanna buy a next phone
6 Comments
fvo_jr
I am aware that Samsung's Snapdragon 8 gen 1 is more power hungry than the one's made by TSMC, but the issue is likely that your battery health is low. You can run a diagnostic test in this app by going to Support tab on the bottom > then Phone diagnostic. If everything is good there the issue is with your apps. Put the ones you don't use in Sleep or Deep sleep to improve background app usage. I can get 6 hours of screen time on my s10e and my battery is 1900mah smaller so this shouldn't be the case for you
MJOFFICIAL
I did all that
Plex
What apps you have besides the pre install? I have turn off all notifications except for whatapp and use adaptive battery mode.
MJOFFICIAL
How much hours u get
Plex
I have s23 . I charge my battery to 80% and would get 1 day and half on that charge. Did you run a battery test using the diagnostics ?
MJOFFICIAL
It's brand new phone s22 ultra I'm talking. Bro
