battery drain a bit bigger than usual
(Topic created on: 10-14-2019 06:16 PM)
Arithe_Ferrari
Questions
Is anyone dealing with this issue aswell?
6 REPLIES 6
Parad0xat10n
Questions
same issue
racedog
Questions
I'm havi g this same issue. I just cleared the cache partition and will see if that helps.
aNDeveloper
Questions
mine is draining fast aswell
racedog
Questions
I've cleared cache and battery drain appears to be draining fast after.
LaFlame713
Questions
nope no battery drain at all.
SamsungUSABetaTeam
Questions
You may experience slight battery drain for a dew days after installing beta. However, if battery continues to drain even after few days please send us an error report with screenshots from One UI Beta App (Beta Feedback -> Send feedback-> Error Reports -> "Select Category" -> Input frequency and Description" -> Send (Top Right Icon) . We appreciate your help for supporting beta program.
