BT Sound Control
(Topic created on: 10-29-2019 03:07 PM)
ChrisZuniga
Questions
Before the update, I was able to control the volume of whatever I was listening to on my phone and my headphones with separate levels so I was able to change them individually. But after the update the volume is the same for both. When I change the volume on my phone it turns up the volume of my headphones or speaker. Same thing vice versa. Is this feature gone or is it just turned off after the update? I can't find it anywhere even on the Sound Assistant app there's no option that changes this
2 REPLIES 2
Not applicable
Questions
By a long shot, did you check the developer menu option which reads "Absolute Volume Control" or something bluetooth related to that?
SamsungUSABetaTeam
Questions
Thank you for your post. We appreciate your contribution to the Beta community.
