dual audio problems
(Topic created on: 10-30-2019 01:24 PM)
itsjustlittleoldme
Questions
Before beta I was able to connect to my car and my headphones at the same time. After beta, it got rid of the dual audio menu, and now I can get it but it's a hassle and not instant like before.
4 REPLIES 4
SamsungUSABetaTeam
Questions
Please try clearing the system cache and rebooting your device.
If issue persists, please send us an error report with screenshots from One UI Beta App (Beta Feedback -> Send feedback-> Error Reports -> "Select Category" -> Input frequency and Description" -> Send (Top Right Icon). We appreciate your help for supporting beta program.
Chuck_Zer0
Questions
Settings, sound and vibration, seperate app sound
Questions
That isn't the same as dual audio was
Chuck_Zer0
Questions
was just an awkward suggestion as I've never used Android auto. thank you for the insight though I now know not to recommend such an idea to other people that may be experiencing the same problem as you say it is not the same thing
