edge lighting not working work smart pop up
(Topic created on: 10-24-2019 07:44 PM)
frankster
Questions
So before I got the beta the edge lighting would work with smart pop up for message notifications but now I have to disable smart Pop up and the lighting works. Any other yesterday have this issue
3 REPLIES 3
Questions
I was just curious. Did you do a factory data reset after you joined the Android 11 One UI 2 beta? I didn't and kept putting it off but I just did this evening and it helped and opened and installed new features that I didn't have before I did it.
Questions
That may help your issues if you haven't.
SamsungUSABetaTeam
Questions
Thank you for your feedback. If you have not already raised an error report for this issue, please send us an error report with screenshots from One UI Beta App (Beta Feedback -> Send feedback-> Error Reports -> "Select Category" -> Input frequency and Description" -> Send (Top Right Icon). We appreciate your help for supporting beta program.
