viknucklhed
10-29-2019 03:22 PM in
Questions
I've noticed the fingerprint sensor location during the day on the GS10 plus is intermittently blinking.. At night the sensor is always visible.
3 REPLIES 3
jhs39
10-29-2019 04:54 PM in
Questions
Are you using a timer for the AOD? You can go into fingerprints and see how you have it set up. I think the always show sensor location only works with AOD--otherwise the options are for it to blink when motion is detected or never show.
CiaoJules
10-30-2019 08:50 AM in
Questions
Same issue here. If I'm using the phone and then turn off the screen and it goes to AOD it won't blink but if if for whatever reason the screen comes on again and then back to the AOD without me unlocking the phone it'll start blinking.
SamsungUSABetaT eam
10-30-2019 11:58 AM in
QuestionsThank you for your post. If you would like to make a suggestion for new feature, please create a post under Suggestions section.
