disable Background power use and background location notifications
(Topic created on: 11-16-2019 06:23 AM)
user12348482
Suggestions
These "features" do nothing but clog up the notification bar with useless data that is 99% unactionable. If we're not able to disable the notifications, please at least us exclude certain apps. I have certain apps set to never sleep and yet they appear as using background power. I'm aware things like nest and smart things are getting my location. They're supposed to.
The notification fatigue from these make them useless.
1 REPLY 1
SamsungUSABetaTeam
Suggestions
Thank you very much for your suggestion. Your suggestion has been communicated to the developer and the development project manager is reviewing the content. After reviewing your suggestions, we will apply them to the official version if your proposal matches our concept.
