Give more options for power modes
(Topic created on: 10-28-2019 08:17 AM)
aknk42
Suggestions
Some regressions from Android 9 One UI:
-can no longer set resolution in optimized mode...I don't want to use FHD+ but I don't want to have high performance's higher system speed (more battery drain). It doesn't make sense that you can set resolution in medium power saving but not Optimized Mode
-option to turn off permanent dark mode in medium power saving
I would prefer both. There's no reason to take away the option that was there before...
2 REPLIES 2
Eximorph
Suggestions
you can not change the resolution in device care but i can be change in display option.
SamsungUSABetaTeam
Suggestions
Thank you very much for your suggestion. Your suggestion has been communicated to the developer and the development project manager is reviewing the content. After reviewing your suggestions, we will apply them to the official version if your proposal matches our concept.
