System volume slider does little to no difference in system volume
(Topic created on: 08-06-2022 10:45 PM)
MaxChang
Support
Currently had a brand new S22 Ultra but the volume slider for Sytem did little to no difference in volume change. System sound like taps on keyboard are soft when through galaxy buds. However, the the rest are working as it should.
I don't think it's a hardware issue, cause audio such as Spotify or YouTube are sound loud as it should via Bluetooth or speaker. Issue are keyboard presses, screen unlock, those system sounds, are too soft even at max volume especially via Bluetooth.
Could be an issue with the latest update?
1 REPLY 1
SamsungNantakkumar
Support
Hello MaxChang. I am Avinash, from Samsung.
We're sorry for the experience. Can we trouble you to perform the following troubleshooting steps?
1. Soft Reset (Force Restart)
2. Safe mode
3. Software Update
Kindly refer to the link below for further detail in regards to the troubleshooting steps above and perform the above-recommended steps only: https://www.samsung.com/sg/support/basic-troubleshooting-tips-for-galaxy-mobile-devices/
However, if the issue persists, we would like to propose the Smart Tutor. The advantage is, that we will be able to assist you with further troubleshooting over the call. Please call our Samsung Care Line at 1800-726-7864 regarding this service. Our experts at Samsung Care Line will advise and assist you in detail.
Hope this can help you.
Thank you.
