BATTERY DRAIN FIX
(Topic created on: 11-14-2019 06:39 AM)
Taheeerrr
Tips
just untill yesterday, my battery life was absolutely terrible so I went to check my battery usage AND an app was on the background for 15hrs while taking 80.9%. after immediately deleting it my battery was back to normal
SO,  if any of you guys have the McAfee Security For T-Mobile App DELETE IT NOW. It runs in the background so much it's actually crazy
this was the case for me so hopefully if you have the same issue it gets resolved :smiling-face:
5 REPLIES 5
Tel864
Tips
LOL, Even in Windows McAfee is a process hog.
joeym
Tips
pretty much lol. best advice: just don't use McAfee. ever. anywhere. it's a bad bet all around.
Evron
Tips
I learned that awhile ago and it would also start a siren lost phone screaming sort of noise just randomly at times I uninstalled months ago I don't blame you
SamsungUSABetaTeam
Tips
Thank you for the valuable tip. We appreciate your contribution to the Beta community.
Tips
I deleted it as soon as I got my S10e
