Resolved! Solved
Galaxy Buds Live problem
(Topic created on: 12-21-2023 04:43 PM)
harleymerlin
Wearables
Has anyone encounter this issue? Look at the battery and time. It's draining so fast. How to fix this?
2 Solutions
Mchhh
Wearables
Have you tried resetting the buds? Maybe it can help.
If not, consider an upgrade to other Galaxy Buds (other TWS.l
Mchhh
Wearables
I'm glad to know! :)
If you don't mind, would you rate my reply as caccept solution"?
Tap the three dots on the right.
Thank you in advance.
9 Comments
Mchhh
Wearables
harleymerlin
Wearables
How do I reset it? I just bought the buds tho 😭
I already google and found the way. Done the reset and trying it now. Thank you for the information.
Mchhh
Wearables
Alright. If battery does not improve, upgrading is your only option (anything is better than those beans anyway 😆)
harleymerlin
Wearables
It's better omg 😭 only goes down 10% after half an hour. Thank you 😭
Mchhh
Wearables
harleymerlin
Wearables
Done!! Thank you again!!
amiratul
Wearables
How's now? Is it ok?
harleymerlin
Wearables
Yeaaaa!!! The user above's tip actually did it!! Hehe 😆
GalaxyNoteFit
Wearables
Galaxy Buds Live is old ready.Batery draining ready after long use.
