12-19-2024 11:16 AM in
Wearables
With the Galaxy Buds3 and Buds3 Pro, you can control your music, your phone calls, and a number of other features by using the Pinch Control. Also, should any issues arise, there are several simple methods to troubleshoot the complications.
Pinch Control
Press the pinch area until you hear a clicking sound.
- Single pinch: Play/pause song, Answer/end call, Stop using the “Read notifications aloud” feature, Stop using “Voice detection” or “Siren detection” feature
- Double pinch: Play next song
- Triple pinch: Play the previous song (If you pinch the earbuds three times after 3 seconds after music starts playing, the currently playing music will play from the beginning)
- Pinch and hold: Turn on preset function (default: noise control mode), reject call
Swipe Control
Slide your finger along the swipe area.
- Swipe up and down: Adjust volume
Set up Earbud controls
“Earbud controls” settings in the Galaxy Wearable app allow you to enable or disable various Pinch Control features on your Galaxy Buds3 / Buds3 Pro.
* The Galaxy Buds3 / Buds3 Pro’s charging case needs to be opened to activate the settings menu.
* You can also swipe the device image at the top to move to the settings screen of other connected devices.
Step 3. Select Earbud controls.
04-25-2025 08:35 AM in
Wearables
