A55 UI 7.0 Battery Drain Issue
(Topic created on: 05-27-2025 12:24 AM)
Jibsgibs
Grabe hindi pa ako nag update but seeing so many issues specifically faster battery draining. I'll wait nalang muna
4 REPLIES 4
tsampoi
Indeed. I’m also hesitant to update, as it’s quite frustrating when the battery drains quickly and the device overheats. according to those who have already installed the update. I might end up regretting it later though, haha😂
reigne214
after installing, try battery reset by dialing *#9900# tas hanapin lang batery reset tas restart fone..maybe it will work..tried it wid my s24+ tsaka sa a73 5g ko, so far kumunat batery draining if ndi ginagamit sa games or marathon movie watching..sa a54 ko naman, ndi uminit wyl diwnloading ako ng ui7 tas after installing, nagwatch ako ng apps na baterry consuming para madrain tapos recharge after 5% battery ko..ok naman performance ng units ko..😊😊😊
itoshi_10
The battery drain issue is based on your phone performance and usage, I'm unfortunately a light phone user. As an A55 user, I haven't experienced it yet, and I updated my device on 21st May. I charged my phone once a day but made sure it was fully charged so I could use it for the day. Although, even with the new update, I made multiple retouches, such as enhancing the adaptive refresh screen rate, but the battery doesn't drain that fast than before One UI.7. I use standard and power saving the whole day in One UI.6.
Watots
Luh kami lang ata ang mabilis magdrain
