battery drain and poor network
(Topic created on: 12-25-2020 12:51 AM)
CYLim
Galaxy Note
Hi.. Im CYLim . Im using note 10 plus for a month , im facing battery drain problem and poor network issue .
1. I went to sleep with my network data is on , after 7 hours my battery dropped 30% .
2. My signal bar is only 1 while my A50 is 4..
Did anyone of you encountered the same issue ? Can give me any suggestion..
Thank you..
13 REPLIES 13
Reshsu
Galaxy Note
same problem..10 plus for luxury use only..not for ordinary..when I contact Samsung. samsung marketing manager from KLIA that issue cannot change just use that mobile they answer me
CYLim
Galaxy Note
nothing else can do to solve this problem ?
Reshsu
Galaxy Note
this model chip compare other model..10 plus worst
Thevar
Galaxy Note
did you use smart switch to carry forward apps?
CYLim
Galaxy Note
yes , right after unbox the phone , but after factory reset on 22.12.2020 by samsung service centre , i manually download back those app..
Thevar
Galaxy Note
so it has been 2 days after reset. use and see for another couple of days. i had battery drain problems when i smart switched apps. but after reset and a week or so(manually install apps), battery life has been good.
CYLim
Galaxy Note
thank you thevar , i will try..
Whitestallion
Galaxy Note
exynos? my SD N10+ no such issue. but update is darn slow
CYLim
Galaxy Note
yes.. exynos
