battery drain and poor network
(Topic created on: 12-25-2020 12:51 AM)
CYLim
Galaxy Note
Hi.. Im CYLim . Im using note 10 plus for a month , im facing battery drain problem and poor network issue .
1. I went to sleep with my network data is on , after 7 hours my battery dropped 30% .
2. My signal bar is only 1 while my A50 is 4..
Did anyone of you encountered the same issue ? Can give me any suggestion..
Thank you..
13 REPLIES 13
Reshsu
Galaxy Note
use dual sim..and try
Reshsu
Galaxy Note
when use dual sim..u no that fact
CYLim
Galaxy Note
i use one sim only..
Edwardpor
Galaxy Note
hi all, i am using S20FE . the signal reception very bad compare to my old xiaomi phone . aways disconnnected or no network . any 1 having this issue? even worse when at indoor.
