Battery draining on Note10+
(Topic created on: 11-20-2021 10:32 PM)
JohnLerryyy
Galaxy Note
Ako lang ba? Ang bilis mag drain ng Note10+ ko nung nag update ako :3
6 REPLIES 6
SamsungRightCare
Galaxy Note
Hey there! Amazing day! As for your concern, have you checked the settings of your device for new turned-on settings that may affect your device? Also, please check if there's an option for "adaptive refresh rate" and if that one is turned on as well. Hope to have helped you. Keep safe. 😀
JohnLerryyy
Galaxy Note
I barely got 4hrs SOT on my Note10+ should I replace the baterry?
SamsungRightCare
Galaxy Note
Have you also checked the diagnostics on your Samsung Members App? Should the problem still persist, we then suggest you bring your device to your nearest Service Center for battery replacement.
JohnLerryyy
Galaxy Note
Yup the battery is good according to diagnostic app.
JohnLerryyy
Galaxy Note
IamRhai
Galaxy Note
Did you get your device as "brand new"? How old na ang device? How do you use it? Maraming mga factor na contributory.
