Resolved! Solved
Battery Past to Drain
(Topic created on: 02-16-2024 03:47 AM)
lindher
Galaxy Note
My Phone Galaxy Note 8 battery is Past to Drain..how to repair it..
Thanks
TeamGalaxyDD
Galaxy Note
Hey lindher!
Glad to hear that your Note 8's still kicking 😄 Phone batteries deteriorate over time, leading to faster discharge times.
You may bring your device to a Samsung Service Center and ask for a battery replacement - a fresh battery will make your device feel good as new!
Visit https://www.samsung.com/ph/support/galaxy-battery/about-battery/ to learn more about how battery deterioration affects your phone.
5 Comments
TeamGalaxyDD
Galaxy Note
Hey lindher!
lindher
Galaxy Note
Thank you..
SonnyCalooy
Galaxy Note
If no fix, you can try advice in video in youtube
Galaxy Note
Try to reset your phone, you might have downloaded fast draining apps. Reminder, backup your phone first thru smart switch via usb, before you reset.
ami_s
Beginner Level 3
Galaxy Note
best way is to replace the battery
