Problem with incoming calls
(Topic created on: 04-10-2021 06:47 PM)
Nasir1518
Galaxy Note
Why does my note 20 ultra keeps rejecting calls after 5seconds ringing?anyone have the same problems?is the new update mess with the calls setting?
5 REPLIES 5
Galaxy Note
You should report this to livechat team, this might be an april update issue
Nasir1518
Galaxy Note
Yes i had reported...tqvm sir..but when i inserted the sim to other phone,it is normal...also when i inserted other sim inside note,the calls was not rejected also..maybe it was the latest update..
Visva11
Galaxy Note
Same here, but I'm not sure whether it rejected the call or not. I don't see the ringing but just the notification popping up missed call
Nasir1518
Galaxy Note
I'd noticed now after the update,my calls also disconnected if the signal strenght changed from voip to 3g..before it was okay speaking while on the highway...
Visva11
Galaxy Note
Have u submit any report?
