wifi problem
(Topic created on: 01-30-2020 12:38 PM)
MrHareth
Beginner Level 4
Galaxy Note
after last software update for my note 9 , wifi started working badly,  i don't know why but after connecting on any wifi for maximum 15 minutes it's stop receiving or sending any data ... until i disconnect and reconnect on wifi .
do you have same problem 🤔
3 REPLIES 3
UnknownUser
Galaxy Note
you may reset for network settings
MOD_1
Galaxy Note
Hi MrHareth,
This is Moderator from Samsung Members Community.
We feel so bad for your experience, we really hope the connection will back to normal soon.
We need your cooperation to provide some print screen and information to us for further investigation.
1. Device IMEI/SN (*#06#) - optional
2. Location having issue - we will send technical support to check the connection at the area.
3. TELCO. Working on 1 SIM or dual SIM
4. Details symptom description
5. Details reproduce steps - Please let us know how you reproduce this issues.
6. How frequent symptom happen.
7. Problem binary (Confirm on *#1234#) - print screen is needed.
8. Time range where normally problem occur.
Except IMEI number, the rest of the information you can share at here if you agree with it.
We will escalate to related team and conduct network testing at the location you mentioned.
However, if you have privacy concern, you also can escalate your details through Samsung Email Support ( https://www.samsung.com/my/support/ ).
Once again, we apologies for all the inconvenience caused.
Thank you.
Emtiaj
Beginner Level 3
Galaxy Note
I am having same problem. Wifi not connecting properly.
