April Security Patch: Battery Drain issue
(Topic created on: 04-29-2026 06:21 AM)
Jnoitab
Recently i encounter battery drain issue after security update and now nag ooptimize na siya and i think may difference yung battery consumption ko sa mga na unang post ko before but my battery life consumption is good as well.
Excited na rin sa upcoming One UI 8.5 update💚
According sa leak, this1st week of May angstarting rollout update ng One UI 8.5
Sa mga naka encounter ng battery drain issue this April Security update at mag tatry ng other option to resolved the Battery Drain issue usingWipe Cache Partion,Samsung already removed this option due toUpcoming One UI 8.5 update to observed and to ensure the seamless update kasama na doon yung pag Clean ng Old Cache files, in short no need to use the old method, naka automatic removed na yung mga old cache file that can cause Lags, bugs, framedrops and battery drain issue after the update.
This will be our first experience with the upcoming One UI update na walang "Wipe Cache Partition".
0 REPLIES 0
