04-07-2024 12:38 AM in
Galaxy S- Mark as New
04-07-2024 01:30 PM in
04-07-2024 02:36 PM in
04-07-2024 10:35 PM in
Galaxy SFor example, at my home, I only get 2 bars with 4g, and at my workplace, I can get full bar with 5g. It depends on the location.
04-07-2024 10:59 PM in
04-07-2024 11:09 PM in
04-08-2024 07:34 AM in
04-08-2024 12:48 PM in
04-11-2024 06:25 PM in
Galaxy SHope you have a safe journey home and Selamat Hari Raya to you and your family.
04-08-2024 02:31 PM in
Galaxy SHi @Fadhullah,
You could try one or more of the following:
a. Reset network settings;
b. Try without a phone case;
c. Try with a different sim card but the same network;
If these does not work, there might be an issue with the antennae - best to check in with an authorised service centre on this. You can reach out to them via the members app > support tab.
Hope this helps!
