How to fix this on my s6 edge??
(Topic created on: 03-07-2020 03:29 PM)
NEXON97
9 REPLIES 9
scinex
Hi Bro. Looks like it's hardware issue, to be precise your screen. No other choice than to replace it with a new screen, or easier way is, to upgrade to a new phone. S20 is calling you my friend 🙂
NEXON97
😅thanks bro, I will think about it💸💸
Valkryn
Beginner Level 3
wait for note 20 lor..hahaa
NEXON97
Nope, 😂not note 20... ✔note30+... Lol
Sy3ney
Expert Level 3
screen problem need change a new screen
CheesedCaked
This is happens is because due to the phone processor's heat that damages the ribbon cable or the circuit.
NEXON97
Owe??... I think that is true... Because this S6 edge always overheating.
CheesedCaked
yeah, a problem with older phones
may i know, im s6 edge plus user btw, what is the best solution to avoid from phone overheating.. I already use many kind of apps, but it's all same .. any suggestions?? one more pls don't ask me to turn off background data or
