I have an issue with my signal. Who can help me?
(Topic created on: 04-02-2025 02:16 PM)
dattis
When I enter the any building I lost my signal and it's searching and drain my battery. I reset my phone and it's steel remaining
4 REPLIES 4
reset your network settings. u can also observe which telco has the best coverage in your area on their websites.
capedbaldy
Following up to @nazzzz's reply, you should also check network strength (ookla speed test or similar), and re-insert or replace your SIM card, older sim cards have this issue of not connecting (I had this problem)
oNeuNo
It sounds like your phone is struggling to maintain a signal indoors, which can drain the battery quickly. Try switching to Wi-Fi calling if available, checking for carrier settings updates, or testing with a different SIM card to see if the issue persists. If nothing works, it could be a hardware or network issue.
aaronradzi
Sorry to hear that what u r facing.. sort of remedies been shared by others members and hopefully ur problem solve asap.. and hope u r not facing THE OTHER part of unsolve network issues where tried many step to settle but at the end stressed u out 😅
