I need help
(Topic created on: 05-15-2025 04:24 AM)
Ayzden
So I upgraded my S23 Ultra to One UI 7 on May 2, 2025. There were no problems until now. Earlier, I experienced overheating and fast battery drain. This has not happened before, only now. I was playing games, yes, but before it did not heat up like this; it was just warm. I don't know if I am overanalyzing things and if this is normal for my phone. Any help or tip would be great, thank you in advance.
10 REPLIES 10
butete
wipe cache partition in recovery mode
Ayzden
Dont the software updates do that already? If not how do i do it?
butete
no its a process you do manually and also helps alot
Ayzden
How do you do it
butete
connect device a computer then you need to power dowb device power on press. volume + and power button to invokr to recovery menu
Ayzden
I did it and it still gets warm while browsing on light apps, wthhh
butete
try device pn safemode and check if still get warm, whats tbe type on case are you using
butete
are you on data connection or wifi
Ayzden
Wifi
