Overheating and battery drainage issues
(Topic created on: 04-03-2025 08:08 AM)
RENZIEE319
Beginner Level 4
Hi hello everyone. It seems that my s22 ultra is always overheating everytime I use it, I already set my background linit to only 3, but its still overheating, second of all the battery drainage, its always low battery even if I don't use my phone. I'm just asking if you all have ideas or tips that can help me tyy goodnight👁👄👁💗
4 REPLIES 4
Mogay
idk if this could help you or not but you can use 60 Hz screen refresh rate and put your internet connection to 4G as maximum connection, only connect to 5G when you need more speed to download huge files, then turn on "light performance" inside device care: this option to use lower frequency of CPU except for gaming, last always restart your phone once per week
butete
+1 dont use 5g stick to lte when on data connection
RENZIEE319
Beginner Level 4
thank you so much, now it doesn't do lag and overheating but my battery is the same, it drains fast just like before
yanyan2408
Get it checked
