Power Button is not as clicky than the volume keys on s23 ultra
(Topic created on: 08-22-2023 08:38 AM)
rokr
Do you own a S23Ultra?
Have you ever noticed that the power button is flatter or not that clicky than the volume keys?
It's like when you click the power button, its like it's deeper that the volume keys and kinda wobbly. Please take note that this test is without a case. You can't notice it if your phone have a case.
I can't remember if it is already as it is when it came out of the box.
4 REPLIES 4
Zajjj
Mine is as clicky as the volume buttons. Maybe it's just that the volume keys are higher when you compare it to the power button? 😁
EllisKai
In my case, I feel like the buttons are at the same height and are both clicky esp with a case.
dulber
Now that you mentioned it. I took the case off. You may need to have your unit checked. My power button is as clicky or clickier than the much longer volume rocker. It has the same amount of protrusion from the frame as the volume. If I try fiddling with both, I can make em budge a bit but that's me forcing them sideways. Along the frame there is no movement.
TeamGalaxyDD
Hey rokr,
Loose buttons may be a sign of something not functioning properly. This could have been caused by a loosened part from a prior impact or adhesives failing - can't know for sure without a thorough checkup.
We'd love to have you at any of our Samsung Service Centers for a check-up! You can book an appointment from your Samsung Members app, or call #GALAXY to set one up 😄
