RCS not working after smart switch
(Topic created on: 07-01-2025 05:33 AM)
RBrian
I changed my phone to S25 Ultra from S23 Ultra, and then I couldn't use my RCS anymore. I'm a Globe user. Is there a workaround?
7 REPLIES 7
vervain88
It happened to me sir.. try to uninstall updates of the RCS then update it again.
RBrian
How do i do that?
vervain88
Long press the message icon then you will see like letter i in the upper right corner tap it then after that you will see app info then you will see the 3 dots on the upper right corner then tap it and you will see uninstall update
RBrian
Did it work on your device sir?
vervain88
Yes as I said before it happened to me, nothing to do with the device
vervain88
Just try it ..
daddYnoRmS
globe disabled RCS since last year for new sims and sims that switched phones. it happened to me when i transfered my globe sim from asus zenfone 5 to samsung a34.
RCS Status: 'Not Supported' - GLOBE TELECOM (PH) : r/GoogleMessages https://share.google/cjXFwA4dDxmKDxWYY
