Resolved! Solved
S20 Ultra 5G Screen Flickering and Heating Issue After One UI 5
(Topic created on: 12-07-2022 05:28 AM)
MaamJulie
Please release a patch update. The problem isn't the screen but the update that heats up the device and flickers the screen. How did I know? Because the boot up screen and always on display isnt flickering only the home screen. The heating issue immediately start after you exit the always on display or after unlocking the screen to proceed to the home/main screen. Please do an action immediately before this bug totally destroy our display and battery. Your expensive service and part replacement sn't worth the price.
TeamGalaxyRene
Sorry to hear that, MaamJulie, about your Samsung Galaxy S20 Ultra 5G having issues with screen flickering and heating after an update and we apologize for the inconvenience it caused you.
You can submit an error report through Samsung Members app as follows:
Step 1. Long press Samsung Members icon on Apps screen and tap Error reports.
Step 2. Tap OK on agreement popup to send system log data.
Step 3. Select Symptom category "Display" & "Power/Battery/Charging".
Step 4. Describe each problem in details and SEND.
How to submit an error report on Samsung Members app? | Samsung PH
If the problem persists, immediately bring your device to the nearest Samsung Authorized Service Center.
https://www.samsung.com/ph/support/service-center/
For more assistance, you may contact us on our online Samsung support channels below.
https://samsung-livechat.sprinklr.com/seao/ph/index.html
Or contact our Samsung direct hotline numbers below.
#GALAXY or #425299 [Mobile Phones & Tablets]
Available 24/7
1-800-10-7267864 [All Product, Toll Free, PLDT]
1-800-8-7267864 [All Product, Toll Free, Globe]
842 221 11 [All Product, Landline]
Daily (8:00am to 8:00pm)
Hope this content is helpful and your device's problems gets solved.
15 REPLIES 15
TeamGalaxyRene
Available 24/7
MaamJulie
Thanks for this badge. Hoping to contribute more helpful solutions🫶Screenshot_20221209_192710_Samsung Members_1000000043_1670585230.jpg
Rochrj01
Beginner Level 4
Same problem for me
Dewg88
I had the same issue yesterday after upgrading from Android 12 to Android 13. As usual, Samsung gave a stupid answer that your device is out of warranty, and you need to pay **bleep** amount to replace the screen. Wake up Samsung, there are so many people having the issue, and you're indirectly robbing your customer.
MaamJulie
The only solution is to replace the display chip of the display which is attached on the displays flex cable. Hoping that I we could find one since AMOLED display is so expensive.
Mhyyy
I just noticed today that the screen of my Samsung S20+ is flickering. Maybe it's bcos my phone is always in dark mode. But when I opened an app with a white interface, I noticed that the screen is flickering. It's really distracting.
MaamJulie
Sorry to say this but you need to replace the screen and it's expensive🥲
Mhyyy
aien0427
How much?
